03 pro x 440 fan jetting.
XC Elko
Anyone know the jetting size for -20 below zero? Putting in a tempaflow. Need to make sure I have correct jet in. Thx in advance...
garageguy
I have a tempaflow in mine I run 340 clutch side 330 mag side. Mine is not stock so you could get by with 330, 320.
XC Elko
Directions and online video say to use the jetting for the coldest temperatures you would typically run into and it will lean it out from there. That way it will be rich enough should you ride in that temp. We ride up lake of the woods at least once a winter and it isnt uncommon for it to be -25 degrees when leaving in the morning for ice fishing. I found the service book for this sled. Looks like 600-1200 ft; 320 pto/310 mag #3 needle slot for -10 to -30 degrees. I might richen up one size just to be safe.
garageguy
I have some engine mods so I run two steps richer. You can always move the needles up or down or adjust the tempa flow a bit to fine tune if its really cold. I also close my hood vents when it gets real cold.
