Check your servo motor on a stand at wide open throttle and see if your servo is opening and closing. If it is not moving it probably is a servo motor code.
We did check when first started and it does cycle once, seems to be working normally. It does not seem to running hot. As long as the throttle is in wide open position most of the time the light will flash steady. Any less and it wont flash.
