Anybody else have an issue with these things? If there is an ounce of humidity in the air and its below 32 degrees my windows absolutly will not open. Tried lubeing the seals and nothing works. I just removed the outer sill rail and there is a ton of moisture in the seal. I am assuming thats what is causing the freezing issue. Is there a updated seal available?
Thanks in advance.
Thanks in advance.
