'05 F7...quick question about D&D's PAC system
nplathe
I'm just wondering how you can adjust the fuel pressure on this system. I know it's a fuel reducer at WOT, but it's currently running about 47 PSI and after talking to BMP they said anywhere from 42-44 PSI is where it needs to be running. I tried calling D&D today, but it was busy. Just wondering how I properly set the fuel pressure with this system. Thanks. Nick
scott_d
I believe its 2 1/2 turns from full close, should put you around 42. Also you need to read the guage at full throttle, not at idle.Good Luck!!!
