05 skidoo rev 600 sdi elec issue
toby1
i have a 05 600 sdi gade with elec start .yesterday we stopped for gas and when i started it the check engine/coolant and battery lights were on .the speedo and tach did not work .the digital read out said scale .it ran fine right up until i restarted it .everything else works fine .runs great .ran it the rest of the day warmers/lights everything works and runs great .has anyone seen this .i have put it out on dootalk also .thanks for any help .
Your odometer/trip meter/hour button is definitely stuck. It is asking you to select a units scale. I've had the same issue on both my 04 and 05's. Usually I can correct the problem by wiggling the button. It baffles me as to why this disables the tach but it does.
Hope this helps.
Skidooski
Hope this helps.
04 rev 600 sdi. I also have had the same problem, button is stuck.
