snowdance
After tearing things apart to fix my broken recoil rope and replace the coolant overflow tube, I discovered I have a gas leak. Well, already suspected due to a spot under snowmobile and gas smell.
I started checking all the fuel lines to no avail, pulled the airbox and think the leak is at the bottom of the clutch side carb. I am a novice and have no clue how to diagnose what is causing this. I feel the bottom side of the carb and its wet with gas. But there is also some gas a little higher up on the clutch side of the carb. I could tell because it was clean. There is an allen screw that actually had gas in the hole where the wrench would go. Can anybody help me diagnose what to do next? The fuel line at the bottom of the carb is just a water sediment trap and wouldn't leak fuel correct?
At this point maybe it needs to go to a dealer. Any help is appreciated.
