07 Attak stalls at idle
otis69
My 07 Attak starts fine when cold but after it warms up will stall at stop signs,gas pumps or when i stop. 9500 miles. If it doesnt stall it idles rough. Any ideas?
Yeah probably sensor causing it to run rich at idle. Getting any codes? Run fine at speed?
L
lenny
Take it to a field and run it now and see what it does
Going from memory as I sold my Yamaha a couple of years ago. I believe it's on the outside of box RH side, you should have unplugged it to remove air box if you changed oil, plugs, or battery.
