It may be something as simple as adjusting the suspension to your weight. Sounds like you got too much forward weight and not enough at your traction point. You may have to play with it a bit (trial and error) to get it to your liking. Also, not sure if you're running them or not, but dual carbides can make a world of difference, and a relatively cheap fix. Lastly, be sure to check your ski alignment. Good luck!
