07 iq 600
Tim cashmore
My 07 iq when it gets to 77 mph the motor just stops pulling let off the gas slow down to 68 mph and then it starts to pull again until I reach 77 then does all over has me completely stumped need help thku to any one that a idea of what's happening
mngolf4
Check for delaminated carb boot - I think it may also be referred to as the throttle body adapter. My '08 did the same thing and that's what was eventually found as the cause. Good luck.
polaris62
I had the same sled. Both responses are definitely possibilities. The throttle body adapter plate was prone to failure from the factory the replacement is a better design. Look it over good a crack can be hard to see especially while it's still on the sled. I would suggest taking it off and looking it over good. If you do find it's bad you probably should get a look down in your jugs at the pistons and cylinder walls. Mine acted about the same right before it locked up. Does it die when you engage reverse. That's a warning sign of bad things to come.
groomerdriver
My son's sled had two bad boots. There is an updated boot so when you do buy new ones, make sure they are the latest and greatest.
Tim cashmore
Thku for your response could you clarify exhaust valves need cleaning or replacement I often wondered if they should be maintained
