tundra ron
What do you Polaris guys think of these sleds only 1700 mi. on it all updates done. What should I check for? Thanks
Armstrong steering!
Polaris had the wrong geometry on it and didn't correct that until 08. You can buy spindles to correct it from a couple aftermarket companies that specialize in Polaris parts, and then the sled is good.
Best suspension in the business.
Don't be surprised if you have to replace the rubber hoses in the tank....they were not made to lay around in fuels and additives year around.
Do the work, the sled will reward you with a wide smile. Nothing quite like a turbo on a sled with massive low end torque.
