Pretty much what it says coming out a hose blowing in there.
R reiley99 New member Dec 21, 2014 #3 sw_lower said: too much oil. ? Click to expand... No just started today it was fine before
L lotoftoys New member Dec 22, 2014 #4 You may have a hole in a piston if you have compression on the crank case side. Pull the dip stick or oil fill cap and start the sled. If you have pressure on the oil side you have big problems. I hope not.
R reiley99 New member Dec 22, 2014 #5 I know when you loosen the dip stick it doesn't do it. Last edited: Dec 22, 2014
