09 500ss tnt belt alignment issue
shawn_grams
Have a o9 500ss tnt with 700 miles on it went through 2 belts which it was chewing the outside of the belt off brought in to skidoo dealer they found motor had moved and caused it to be 3.5 mm out of of alignment since then 400 more miles find my belt is starting to chew the same side off and called skidoo and they can not beleive that could be out of alignment again, well ok how did it get out of alignment the first time. this is all covered under warranty but have the hour each way and the headaches has anybody expereinced this issue before or any suggestions would be greatly appreciated. thanks alot!!
smucks
Maybe you should try and use periods in your sentences and not just have one big paragraph of words. It may make a little more sense.
I would trade it in for a 2010.
