09 800R shorty
I'm not brand loyal so let that be said.I like different things from all manu's. Like above I get 10 mpg. and it drinks more oil than my AC. ( hard to believe ). Done some mods , tower brace, Goodwin belt tensioner, and major changes to the front end shocks, springs , wider a-arms,spindles . The 2010's have better shocks up front as do the 09 gades & TNT's. No big issues. Just the normal maintenance ( belts, hyfax, ect... ). My rec, if you buy 1 is to get a couple of models up with the good rebuildable shocks. The Renegades are allegedly easier to tune for cornering. It does give you a work out if you ride more than 150-200 miles a day. They are very fast, no-one will run away from you in the straights. Another thing to look for is coolant leaks, mine still leaks ( when it cools down at night ) after 4600 miles and 4X's to the 2 different dealers. Sorry for the negative report but it is what it is. I won't buy another 1. Maybe a different model. This is not a fair appraisal, I end up modifiying all my sleds for my riding needs. Each manu has it's +'s & -'s. After a couple of years when I get to the 6500-7K mile mark then things start failing. (IMO)
