14 foot v trailer
mojo
Can you load 3 snowmobile on a 14 v trailer.yamaha apex gt a 97 indy 440 and a 700 edge sp.if so how would you do it.thanks
dpd43
14 V Trailer Loading
2 facing forward, 1 facing back. Slide the back ends of the 2 forward facing sleds to the outside edge of the trailer and push the 3rd sled in backward between the front sleds. you could also load them sideways. If you have a decent cover, cover the one facing backwards. If trailer is enclosed, it might be tight squeezing 3 inside.
mn_mxz
I have a Sledbed 14' plus 2' v open trailer, with double axles. I load 3 136" track sleds on my all the time, all facing forward. We have 2 05 Renegades and the other sled is a 06 Edge Touring. I load the renegades on first, them pick up and move the rear ends over to the edge and then drive the other sled in between the other 2. The last sled does hang over the back of the trailer by about 6 inches or so.
mojo
It is enclosed sorry i forgot to memtion that.otherwise it might be tough throwing 440 in a nissian fronteer crew cab box
yamadooed
If its a 14x102"wide enclosed you load two facing the rear door first skis up to the rear door move the seats toward the walls... Then install the third forward facing in the front. Most I've seen this way is two 136" and a 121" up front...
samc
You can put them in facing forward but it's very tight. We've done it with a 144 and 155 and then the 121 up the center but again very tight. You'll be better off loading from the front back. They will fit.
