Wondering if anyone has figured out how to cure detonation problems when forced to buy gas containing %15 ethonal or stagnate premium gas?
My Ski-Doo 800r trips the knock sensor code and retards the timing on certain types of gas. It also seems to happen more often when my gas tank is less than half full.
Things I originally thought to be causing this:
Lean fuel mixture- Not thinking this is the case. Sled gets 11.8 MPG and this is typical for an 800PTEK.
Cracked Carb Boots or Y-Pipe- Checked both and no issues
Irdium Spark Plugs- Changed to regular and still having issues.
Compression too high- Both are reading 140.
Sensitive Knock Sensor- OHMs read within spec.
Some other noise tripping the sensor- I was told some aftermarket pipes can send out a freq. that the knock sensor can pickup. My can is stock and I see nothing else that could cause a high freg. sound.
Fuel pressure too low- Havn't ruled this out. It goes along with this happening more often when my fuel level is low but It also seems to happen more often when gas is bought from gas stations were you know people aren;t buying premium gas.
