2007 Polaris D7
snoeatr
My 07 Dragon lost the speedo. It has the digital gauges and wires instead of a cable to the drive bearing. I am wondering if there is a sensor in the bearing housing or how it works on these. The bearing is still good i already checked it just not familar with this setup and Curious if anybody else has had this problem. Thanks for any advice.
rp7x
no speedo
the speedo pickups do fail often, three wire plug hooked up to bearing cover
motor_slut
It uses a Hall effect sensor in the speedo housing on the driveshaft and they are known to fail. Sometimes you can get lucky and clean it to restore function.
