2009 800r renegade
zappie1213
well i went to go for my first ride and it will not idel or run unless it is choked 1/2 way i clean the carbs checked the needle jets nothing seems wrong what do you guys think it has 9.5 gallons of fresh gas (well i think its fresh it is from the gas stastion)also it is under warrenty till feb of 2010 i was thinking if it was an easy fix i would do it myself thanks for your input
longtrack
Sounds like its running on 1 Cylinder. Pull Plugs look for a wet one. Sometimes the First Ride of the season is good for a fouled Plug. My 500ss fouled one this Year after about 10 miles.
Otherwise Check the Air Box. Pull it off and look for a obstruction.
If that doesn't fix it take it to the Dealer.
