2010 polaris dragon switchback setup
squarepants2
I just put on 350 miles in up on my new switchback. I love the sled but it seems to push. Still has factory suspension settings. I ride about 50/50 on and off trail. Anyone have any good suspension setups ?
xcsp
Stock wearbars on the skis? If so, get rid of them and get some with decent carbide on them.
From there, maybe someone with a Switchback can offer some more advice.
mngolf4
Agree with XCSP. I've got an 08 Switchback and I dumped the stock wearbars (4") quickly and I'm now running 6" with much better performace. Also played with the ski pressure a bit. Just tweak them until you have them "dialed in" - you can definitely tell the difference.
snodogg
I had same problem with my 09 dragon switch, it's a ski pressure problem. Tighten the limiter strap on rear suspension, and increase front ski pressure. If you have the Air 2.0 shocks you will need to spend the extra $$$ on the pump kit. 6" carbides will help but won't fix your problem. Once you get it dialed in you'll love the sled.
squarepants2
thanks for the feedbaqck. I will try limit strap and am replacing carbides. I really like sled so far. Hope you all had a merry Xmas.
