Post this over on dootalk. I bet you will find a set pretty quick over there.[/QUOTE
Good suggestion. Thank you!
Turn up the Middle Spring all the way and turn down the Ski Springs to the lowest setting. If that doesn't do it turn the rear Spring down a notch.
If you do all that it may not turn, but it will steer e
I have a extra set of 5.7 Black/Gray Loops up in my Barn, but I don't think you need them.
Biggest bang for the buck would be to increase spring pre-load on front shock of rear suspension. Don't do 3 things at once or you will never figure anything out. If it is a 13 some set in or spring fatigue has probably occured. Lengthening the limiter strap will not have any effect if there is already slack in it. Put sled on level surface. Have wife sit on sled. Get your head down so you can see the limiter strap. My guess would be that there is some slack in the limiter strap. I do not have a Doo but I am sure adjusting the front suspension spring will suck because it does on just about every other sled. But tighten the spring a little at a time and have her drive it around some. Just go 1 turn at a time until the slack goes out of the limiter strap or until it steers lighter. No need to lock the spring every time just for test rides. If you adjust to the point where there is no slack in the limiter strap and the steering is still heavy then it might be time to lengthen the limiter strap. Tightening the front ski springs is the opposite of what you are trying to do. That will put more pressure on the skis making them harder to turn.
Looking for a nice used pair of 5.7 Pilot Skis for a 2013 Rev. Black in color. Bought a brand new pair of USI triple threat skis and wife did not like them. Selling the USI and going back to 5.7. If you have some for sale please let me know. Thanks
With all due respect coming from a guy that has had annual new Doo's from 03-18; these skis were some of the best skis ever.
May I ask why you changed them up?
Bear
If you do all that it may not turn, but it will steer easy.
Just wanted to try a new ski. Looking back I should of just left it alone. Thanks to everyone for there responses. Will be going up at the end of the month and will try it out.
