96 jag vapor lock problem
terry_j
My nephew rides a 95 jag 340 and it never fails that with in 10 miles down the trail the sled quits. It seems like it vapor locks. After letting it sit for about ten miunetes, it will fire right back up and go a while then lock up again. any Ideas on how to fix?
Thanks.
98machz
if its a vapor lock,, the vent orfice would be clogged... try and leave the cap open slightly so it can vent... if it still does the same thing,, its not vapor lock... i had a ski doo last season give me the same symptoms,, ended up being a faulty fuel shut off valve,, bypassed it and wham,,sled was fine... check that too if it still does it...
alden
