96 VMAX 600 & SX Clutch
sodakota
I finally got the new skid installed and testing the set up when I noticed a significant change in power and noise. Turns out the Comet clutch spider blew apart. Will an 8CR00 primary clutch from a SX Viper work? Do I have to change the weights and spring and ????? Big ride this weekend and the extra sled would be nice for the family.
jimfsr
You would definately have to change the weights and springs. I don't know if the taper is the same, should check comets web site for commonality. It should say what part numbers fit which models as the comet clutches come w/o wights and springs, the cluch body would be the same, maybe a diff. taper though.
sodakota
Thx - taper?
The taper apppears the same as Yamaha did not spec the "comet" branded clutch. Rather, the "comet" clutch that came off machine was a replacement/improvement.
It seems through some net review that the comet 102c and 108c are the clutches needed for yamaha taper. I have the comet taper spec for the clutch but I can not find the stock taper of the crank shaft.
Any ideas anyone on how to determine/find OEM taper?
jimfsr
The 102 and 108 were manufacturd with many different tapers to fit different machines.They should be the same. I will see what I can find out for ya...
Bolt it on! same springs and weights, same taper. Will work on both machines.
