97 MXZ Track Change
renegade
I had a 99 where I put a 1 3/4 inch track and had to install smaller drive wheels. I would guess that if your studs are not over a 1 1/2" you will only need tunnel protectors. If they are I would do more investigating.
xcr800
That track will fit with no problems. If you start going with larger lugs 1 3/4 or bigger you will have to make some changes. You should be able to go 1 1/2 lugs on track without a problem. If in doubt contact Bluetooth or Gigakessler they are members of this site and very knowledgeable. They can even tell you about the gearing that may have to be changed to get the best performance.
