Had someone do some work on this sled and just now realizing that I think they swapped 2 plug wires (was prepping the sled for summer storage and noticed this). Admitting my limited knowledge about this sled/engine (bought it used and I'm not a full-fledged sledhead), I would assume the plug wires effectively "line-up" with the cylinders as you work your way across the engine. Looking for confirmation on the correct plug wire sequence and then how would the sled "behave" if the plug wires were connected wrong (2 cylinders swapped)?
