sir_switch
After completing a total engine rebuild on my 97 ZRT600, I find alot of excess oil at the bottom of the belly pan. The oil appears to be flowing through the brass nipple on each of the carb boots even after the machine is shut off. I also have an excessive amount of 2-stroke smoke during start up and a bit of backfirring. At this point, the machine will only start once I pull all three plugs and dry out the cylinders, I suspect that I have an oil pump issue but I''m not sure on the proper adjustment or how to confirm that this is my issue. Any thoughts or trouble shooting tips would be appreciated.
