Neighbor guy was moving away and needed to dump his sleds so I picked them up on the cheap. I knew my brother in law was in the market, so I figured the little 550 would suit him well. Neighbor was a tool but I figured with a "little" work the 550 would be fine. Had a little trouble getting it running but figured a good carb cleaning would have it popping off fine cause it runs good when running. Started cleaning sled up and to my dismay found not one but two cans of either, one in trunk and one in dash bag :-(! Compression test is even but only about a 100 lbs after three pulls. Sled has 7500 miles on it.
I cleaned the carbs and still took 10-15 pulls to get it fire. So I raised the inrichiner pucks and it seemed alot better. Sat over night in shop and started on second pull a few days in a row. Sat about 3 days and it took 25 pulls. Warm it starts and runs fine. Carb drop tubes are not leaking.
Think it need to be rerung? Is this a Nikasil motor? Ideas? Thanks
