Trying to find out which hole the spring (yellow) is supposed (per the service manual) to go in on the secondary pulley. There are 5 holes and what is the reaction of the secondary based on which hole the spring is placed. Thanks
Thanks guys. It is in the center hole right now with stock yellow spring and stock clutch.
I did change gearing from 20/39 to 19/40. Manual says peak rpm to be 8400. So I'm assuming I should adjust hole location to maintain 8400 peak?
