99 Blazer Belt Noise
Serpentine belt silent or makes intermittent squeaking noise at any speed or idle. Mechanic says defective belts on market now & not worth spending money to replace as could do same thing with new belt until market purges defective compound belts. Belt ok just makes noise. Is there an additive I can put on the belt to eliminate noise then reapply when it comes back? This is my daughters POS car & she has no budget & on my payroll so I'm just trying to get it to hold together until she is graduates from UWSP in 2 years.
mjkaliszak
I think CRC makes a Belt dressing or belt compound in a spray can. I don't know how long it will stop the noise but just a thought.
Stumper
Clean the pulleys and belt with alchohol.
Clean the pulley and belt with rubbing alchohol. That usually does the job but Cheys are known for this. My 99 burb does the same thing and is worse cold. OEM belt is less lilkely to make noise. Anything you buy at AutoZone or Murrays will make noise eventually.
wags
Rubbing alchohol will dry out rubber in the belt with time, try a drop or 2 of dish soap. Did you service it lately because antifreeze if spilled onto the belt or pully system can cause this.
snow_monkey
Belts will make noise especially when they begin to dry out. A silicone backed belt will be a little better. Previous answer to the thread cant hurt, cleaning the pully helps remove residue builds up. A high quality belt or an oem belt will be the best. I have a trailblazer and just went through this. I expect the noise will come back, I belong to the trailblazer forums and this is common.
dab102999
I always have a bar of dial soap under the hood. when they make noise I just hold that on the belt for a second or two.
abish33
Had the same problem on my wifes 96 went through a couple of belts finally put on a gatorback belt and no more squeal.
