A.L. cam on N.C.N
lizidaho
Hi John,
When I am in N.C.N. and pull up the A.L. cam, the picture updates and the ambient VWS updates.
But, the Snow Data as of 10:00 a.m. is still stuck on April 25.
Thanks, Liz
A
adam
mine does the same thing, it has everything updated as of april 25th, 2007
A
average
If you take the route that lizidaho describes through the N.C.N., the URL that the snowflake calls for is: http://www.johndee.com/alcam/alcam.htm.
If you use the left sidebar menu to call up the A.L. Cam, then the URL is: http://www.johndee.com/alcam.htm.
I believe the two <u>alcam.htm</u> files are not identical. The alcam.htm file in the /alcam/ directory or the snowflake's URL will need to be changed.
Good eye Liz.
lizidaho
Appreciate your help, John. And, Thank you for the hard work and the ability to communicate with everybody. Keep the ads coming!
