Does anyone out there know the pressure in the fox shock on a 02 600 xc sp.
J joe New member Jan 10, 2010 #1 Does anyone out there know the pressure in the fox shock on a 02 600 xc sp.
R raceinsnow New member Jan 11, 2010 #2 The shocks don't use air.Air is bad because it has moisture in it and air will change pressure with temperature changes.The shock requires 150psi of nitrogen.
D Duffy New member Jan 12, 2010 #3 I rebuild these shocks all the time, they require 200psi of nitrogen.
S snodogg New member Jan 12, 2010 #4 I thought the fronts required 300 psi nitrogen and rears are 200psi. better search the net for your specific brand of shock and the corresponding spec chart.
