I'm not sure if it meets the spec for your watercraft but it does for my 06 SDI and works great. The valves are always clean the compression is the same since new. On sale at farm and fleet this week for $12.99 Gal. Here are the specs.
C I T G O P e t r o l e u m C o r p o r a t i o n • 8 0 0 / 2 4 8 - 4 6 8 4 • H o u s t o n , T e x a s • M a d e i n U S A
CITGO SUPERGARD Sea and Snow 2-Cycle Engine Oil is a synthetic blend, low smoke oil designed
for use in high performance air-cooled or liquid two-stroke engines of Personal Water Craft (PWC)
and Snowmobiles.
SUPERGARD Sea and Snow 2-Cycle Engine Oil is engineered for lower smoke and advanced
protection for air-cooled 2-cycle engines. The synthetic blend formula meets or exceeds the rigorous
requirements of the API TC, JASO FC and ISO EGD classifications for 2-cycle air-cooled engine oils
and also exceeds the performance requirements for JASO FA, JASO FB, ISO-L-EGB, and ISO-L-EGC.
This advanced oil helps protect todayʼs high performance air-cooled 2-cycle engines against exhaust
port blocking, combustion chamber and piston deposits, ring sticking and scuffing, and wear. The
JASO FC Certification Number is 001 CGO 535.
SUPERGARD Sea and Snow is formulated with premium CITGO base oils and a new synthetic low
ash additive package that provides excellent lubricity and detergency performance that surpasses
standards for preventing piston and combustion chamber deposits. In addition, SUPERGARD Sea
and Snow is a synthetic blend which reduces exhaust smoke and prevents piston seizure and cylinder
scuffing. SUPERGARD Sea and Snow is prediluted to allow easy mixing with gasoline and smooth
flowing in oil injection systems.
CITGO SUPERGARD Sea and Snow 2-Cycle Engine Oil is recommended for use in air-cooled,
2-cycle applications where an API TC, JASO FD, and ISO EGD product is preferred. It can be used in
either premix or oil injection systems up to 50:1 fuel ratios. It may also be used in certain motorcycle
engines which are liquid cooled. Not recommended for engines requiring an NMMA TC-W3, TC-WII, or
TC-W product.
SUPERGARD Sea and Snow is formulated primarily for use in snowmobiles and personal watercraft. It
can be used in motorcycles, generators, lawnmowers, and hand held power equipment such as leaf
blowers, trimmers, and chainsaws. SUPERGARD Sea and Snow provides the necessary protection to
keep your snowmobile or PWC running cleaner, longer, and with less smoke.
QUALITIES:
APPLICATIONS:
DESCRIPTION:
TYPICAL PROPERTIES:
CITGO SUPERGARD® SEA AND SNOWTM 2-CYCLE ENGINE OIL
Material Code 621612001
Gravity, ASTM D 4052, °API 32.5
Density, lb/gal at 60°F 7.19
Flash Point, PMCC, ASTM D 93, °F (°C) 158 (70)
COC, ASTM D 92, °F (°C) 194 (90)
Viscosity, ASTM D 445, cSt at 40°C 56
cSt at 100°C 8.5
ASTM D 2161, SUS at 100°F 288
SUS at 210°F 54.9
Viscosity Index, ASTM D 2270 126
Pour Point, ASTM D 97, °F (°C) -44 (-42)
Appearance, Color Purple
Sulfated Ash, ASTM D 874, % 0.10
Total Base Number, ASTM D 2896, mg KOH/g 1.1
C 1 0 0 0 8
P R O D U C T I N F O R M A T I O N
C I T G O S U P E R G A R D ® S E A A N D S N O W TM
2 - C Y C L E E N G I N E O I L
D a t e 1 / 0 9
