Anti ratchet Drivers
drmudd
People,
I have a Question? What is the difference between 8,9 and 10 tooth drivers? Besides how many teeth they have. Is there a speed or power difference or do you stay with the stock setting? I'm looking to install these with a 144".
Thanks,
The Doc.
xc700LP
diameter
8,9,and 10 tooth drivers are different in diameter, people will change to a smaller diameter driver for more clearance but that will change your approach angle and also your gearing. what size lug will you be running and on what sled?
xc700LP
I would stick with the same tooth a was what you have right know. You'll need to cut the tips of your rails shorter so the suspension will still cycle through its travel without hitting the drivers, take a look at the pics i have on my mod build thread to see what i mean.
