Iam going to try this on a old shield ,who knows ??
Plexiglas can be a difficult surface to polish and clean. It's difficult to clean it streak-free. A foolproof way to polish Plexiglas is the old-fashioned way--with vinegar and newspaper.
.Difficulty: Moderately Easy
Instructions.Things You'll Need:
Plexiglass
Newspaper
White distilled vinegar
Water
Measuring cups
Squeegee
Bucket
Sponge
Get what you need for every
project at HomeDepot.com 1
Add warm water, on the verge of hot, to the bucket until it is 3/4 full. Add 1 cup of white distilled vinegar (measure 1 cup per 1 gallon of water). Bring the bucket over to the Plexiglas window/sheet you are cleaning.
2
Clean the Plexiglas surface with a wet paper towel beforehand if there are large chunks of debris or dirt, such as mud or stuck-on leaves and grass.
3
Soak the sponge in the water-and-vinegar mixture. Working from the top of the Plexiglas, start on one side and rub across the Plexiglas to the other, firmly, so the solution drips down below. Keep polishing the area back and forth, making sure to get all the corners and surface area soaked and rinsed. Dip the sponge into the mixture as many times as you need.
4
Place the sponge back in the bucket. Take the newspaper and remove one single sheet from it. Fold it in half. Place the flat surface of the newspaper against the Plexiglas, starting in the same position as you did with the sponge. Make back-and-forth sweeping movements to soak up the vinegar and water. Work quickly and firmly back and forth to give the polished Plexiglas a streak-free shine.
5
Dispose of the newspaper when complete. You may have to use multiple single sheets of newspaper for one area of Plexiglas.
6
Use a squeegee if the newspaper does not provide a streak-free polish. After soaking the Plexiglas and polishing with the sponge, use the squeegee to go from top to bottom, starting on one side. Remove all of the drips and solution firmly with the squeegee.
Read more: How to Polish Plexiglass | eHow.com
http://www.ehow.com/how_4896358_polish-plexiglass.html#ixzz1DaLwxL4S
