I have a 01 zr and a 99 zl and noticed the rear shock pivot on the zl is below the idler wheel shaft and my zr was above that shaft. Can or should, the zr's be mounted below that shaft. I moved it below and it seems to be working much better than before and is not rubbing on anything. Thanks for any feed back.
