Hey folks, hope you could throw some ideas my way about this one.
The Sled : 2001 Arctic cat mountain cat 800 with carbs
This year I couldn't get my cat running, and it turned out the fuel pump wasn't doing anything. It runs if you dump fuel into the plug holes. Tried this to pump gas up to the carbs but that wasn't working, so eventually I took everything apart. The line from the pulse fitting was found to be full of oil and blocking the pulse, so I blasted it out with compressed air at M+M. The pump started pumping fuel after the line was cleared, but once I put it back together it still wouldn't start. I suspect that the crankcase is full of full/oil and has just blocked the line again.
Any suggestions for draining the crankcase? As far as I can find out there isn't a drain, so I'm sort of stuck as to how to clear it out. I have lots of hand tools for the job, but no air lines or anything to blast the case out. I'm trying to get a plan in place, I have pulled the rope a billion times by now with no results.
Let me know what you think before I dissassemble this thing in the lot again.
-Jesse
-Jesse
