Bad injectors?
bobsledder
I am trying to save the life of a 93 AC Pantera. It ran last week and now wont start it has spark however they are always wet. When I crank the engine over with the plugs out to check for spark there is a fog of gas coming out of the plug holes. I dry the plugs and cylinders but it still wont fire and the plugs are wet again. I have pulled the injectors and blew them out however I have no experience with efi sleds. Any thoughts?
It sounds like it's flooded the crank case with fuel, pull both of the plugs & keep turning over. Any fuel dripping out the exhaust? After exhausting the fuel, put a fresh set of plugs in & give it a whirl. BTW, I don't think it's a great idea to blow the injectors you could lodge debris into them.-Mezz
