Belt storage on xp chassis
snow_monkey
Solved a problem with the belt storage. On the right hand side above the frame push the belt far to the right as you can and tuck it in and run it along the top of the frame but do not let it push against the plastic for it will cause your hood fasteners to pop loose. Most of my belt is forced over to the right then take a zip strap and bind the belt where the velcro fastener keeps the belt in place, not too tight to not damage the belt. Before this fix I had my hood continue to pop out of its tabs. When you are finished 3/4s of the belt will be to the right of the velcro fastener and you will not have the left hand side pushing up against your coolant bottle or hood. The zip strap goes around the belt only to keep it's shape to fit under the hood properly.
