you will need to play with the settings on your phone to get it to work correctly, if you can get to the main site and not the board then it sounds like a java issue with your phone. The site isn't really designed to work on the small screen of a phone, but will work just need to play with the settings on the phone. I know by default on my blackberry the web settings were very strict, Java wasn't enabled and a few other settings needed to be changed before it could select the menu items on the site.
