lincolnwood
I just traded a kitty cat for an `83 enticer 340. It had been sitting for 4 or 5 years so I drained the tank and cleaned the carbs. To my surprise it fired on the second pull. The only problem is it wouldn`t idle. I took it out this morning and put a couple miles on it and it idles better but still has a low end bog, and will die unless you give it a little half choke or feather the throttle VERY gently.
Do I need to reclean or adjust the carb, or just ride it some more till it comes out of it?
