my brother picked up 2000 550 reed case fan super sport not getting flow/vacuum on one carb. I don't think its with the engine/ignition because we swapped carbs between cylinders and same thing just other cyl also swapped fuel lines from pump to each carb with no difference any ideas it runs but when you put your hand over good carb kills engine & the bad carb you feel little vacuum but keeps running. he dissembled & cleaned both carbs the non working one had the choke stuck open but thats been cleaned & freed up.
any ideas ?
any ideas ?
