CAT 580 HIGH IDLE
rkw
99 Cat 580 is idling at 3000 rpm. Last time I started it a couple weeks ago it idled perfect. I started it last night and waited for the idle to come down as she warmed up. Never did, it stayed at 3000 rpm even with the engine at normal operating temp.
raceinsnow
I would check for a mouse nest in the air box first,or something that is holding the slides open in the carbs/throtle bodies.
Check for obstructions like raceinssnow said but 580 chips of that era did some weird things if not below 32F. Start when cold.
matman
If it has a choke- when it is at high idle try flipping the choke lever a couple of times-if the RPM's drop back then check for binding in those cables or just replace them.
roam
check for cracks in the boots between the throttle bodies and engine..could be sucking air..my cousin burnt up his zr 580 a couple of times because of that
rkw
Thanks Roam and Acbigtwin, you guys were right on.
I did the carb clean test and the RPM changed.
Looked real close at the rubber throttle body boots and both were cracked. R n R boots, problem fixed. Thanks again, I owe you a beer eh
dopp
Craked carb/injector boots.
with engine running spray carb cleaner around boots.idle will change if there are cracks
this is a common problem
