Yeah but this sled is different. It doesnt have a jam nut. It has a lock pin that you insert into to adjusting bolt to hold it from rotating. The bad thing is that if you rotate the bolt 180 degrees tighter to get the pin lined up the chain feels to tight. If i leave it where it is there is some play but not enough to have the chain slapping on the case sides.
