chaincase bearing
snake
'02 600 edge=here's my Q=I'm putting new track in,and its been a bit since I've had a c.c. apart. I noticed that the lower c.c. bearing has seal in it on the c.c. side! I'm almost certain that its factory. just curious,why wouldnt it be left off bearing so it can get lube? I would think some lube would get past it,maybe poo leaves it installed so that shavings or debris cant get to rollers?thanks in advance
garageguy
I would use a high quality bearing and leave the seals on. Some oil will get around the seal, but the dirt and shavings will stay out.
