sledman411
I have a 1978 chevy with a 350 4 bolt main, it has a summint intake, holly double pumper, headers, and thats about it, the motor starts right up, has no problem idiling, it is a 4 speed manuel with a granny low, 1st gear it is fine, goes to 5000 rpms if you want it to, 2nd gear goes good untill about 3100 rpms, then it sounds as if the passinger side of the motor completly shuts off, it sputters and choaks it self, then you shift into thrid, the driving gear, and it is fine at about 2500-3000 rpms, then if you try to accelerate it studders and does the same thing, i just changed the oil, and the fuel filter, as i said it start right up and has no trouble under no motor strain, the oil pressure is good upper 30's and things like that, so i dont know maybe if my timing is off, or i have some bad compression issues, it started doing it out of no where one day, and now it wont go back to normal, i was thinking maybe the timing some how got thrown off, but i dont know, Thanks for the help and sorry for posting in wrong area, i just need help
