Photofinish
What's everyone using to clean running boards and seats? Seems everything I've tried just doesn't work
Pledge polish works great on hoods, it makes them shine and look like new.
It may be a new one for you but not for alot of people try it and you will be suprised.I have also found that OLD ENGLISH FRESH LEMON works better than pledge it must be just a little different in some way.Huh. wd40 and furniture polish. That's a new one.
I wonder if cleaning furniture with "back in black" would work, or if I can lubricate mechanical components with "aluma kleen"?
It is your sled clean it any way you want i am shure the oven cleaner is cleaning.But here is a suggestion it will pull the oils out of the seat cover,you really need to treat your seat with something to put the oils back in or it will dry out and crack or pull apart at the seams.If you trade every year probably not a problem but that seat will be junk in time and if you use the oven cleaner very often it may be sooner than you think.Found out years ago when you wanted to get that brown exhaust color to disappear easy off did the job. You don't want to get it on the aluminum parts or Ur seat for very long but it will do the job. Last week I used it on a seat on a new sled and never had a problem.
