Yes, I have this done every September then have the window washer follow up on the glass. It works well and agree on the 90% or better success rate. Also works on the Asian Beatles (lady bug imposters). The company I use is out of Florence, but they might head out your way. PM if you want their number. BTW, new sled was delivered and I'm heading up to check it out hopefully this week!
My solution to this problem is a little known product from Canada. It's called the Cluster Buster or powder trap and it works wonders. Check it out: http://powdertrap.com/newsite/clusterfly/clusterflies.htm
You will not be disappointed. Also, I have no connection to this company, only a happy customer.
I do remember those but wife nixed would not have them in the house. I'm conflicted just stained logs so not receptive to spraying new stain but would like a Spring & Fall solution to these pests. I have stick vac that sucks them up in sun rooms which is ok when I'm here but can be messy when gone for 2 months or more.
Yep if outside sprayed I would need to have windows washed ASAP too. Yesterday may be the last day of cluster files with snow coming this week. I should bomb the inside been along time since I did that. Looks like you can take new sled around the yard on Wednesday.Put my trailer in Winter position yesterday so good to go.
