clutch removal tools
coldbear
Need to buy clutch removal tools for 2002 800 MX Doo and 99 583 Doo.? Drivens also plus compression tool for secondaries. Any cluch xperts out there with good ideas? Thanks.cb.
salmonbum
I think the clutch puller may be different for the 583, compared to the 800 (which is the more common one). You can use a simple make-shift spring compressor for the Primary governor cup. Secondary is a tough one. Take a long 5/8" threaded rod and clamp it in a vice.
