Crossfire rear suspension question
poprivetus
I am replacing the bushings and axles on the rear suspension front arm assembly on my 2009 Crossfire. Both the bushings and axles were worn considerably. The new long axle fit nicely into the bushings but the short axles that are on each side of the assembly are so tight they would require pressing into the bushings. Has anyone run into this before? Could I have the wrong bushings? Or do I grease them and press them in? The axles are slightly longer then the bushings so I believe the mounting bolt, once tightened, will hold the axle in place.
