sleddawg007
1999 skidoo 583 I have no starter engagemnet and the battery is charged. The starter does not turn. I put a meter on the post where the main line feeds from the battery, and there is 12+ volts there. Is the other red wire to the solenoid the feed from the switch? There is no voltage at that terminal when I turn the key to the start position. Should it not have power? How can I test the starter to see if I have a switch issue or a starter issue? How do you test a switch?
Thanks
Thanks
