DaytonaDave
Good morning....yesterday I uncovered my 2003 MXZ800 which has been sitting for a year or so (winterized and covered outside) ...Prior to winterizing it last it was running fine....I removed the tape from the spark plug holes and pulled the chord to check piston compression only to find oil spouting from the #2 Piston . Yes spouting up through the plug hole and filling the piston...my mechanic thinks its a lower end problem i.e. crank seal or something to the effect...ime thinking its a bad ring in the piston?
Can anyone shed some light on the subject?
Much Appreciated...
Much Appreciated...
