Enclosed trailer sidewalls
fireman
I own Aluma enclosed snowmobile trailer and I was wondering if someone could tell me which way the sidewall studs run. I know that the area where the wood panels meet the studs run vertical and I was wanting to know which direction the studs run out in the middle of the wood panels. I'm wanting to hang some wood cabinets and need the support.
They should run vertical (up & down), spacing, not sure, could be every 16". The studs should be beneath every roof support, if not visible, contact the mfg to verify.-Mezz
I can take pic's and measure mine if you want, as I don't have full walls, just kickers on the bottom, BUT its a Worthington brand trailer, I would thing there all pretty close to teh same
BUT I would still try the OEM< to get exact numbers
a s no point in drilling un needed holes or missing center?
BUt if you want be glad to go check mine, don't have any pic's handy but can get some of them too??
Modman440
Would think they would be verticle a riding buddy of mine had a tree fall on his trailer and tore off the outer wall if memory serves me they were verticle at least what I could see.
MOD
